Astute, and others,
Enlighten us on the post cure process. I am using West Systems, and don’t do any post cure. Is there different temp/times for different epoxys? Should I just raise the temp to a little over the max the hull should see in use, and hold for a few hours? Post cure in the mold?
I have been getting some print through of the weave, and the internal bracing after almost a year of use. Is this from a lack of post cure? Or should I try to figure a way around using typical bulkheads with these thin hulls (2-3 layers 5.6oz S glass).
Never mind, found most of the answers in Dick L’s thread!
http://www.rcsailing.net/forum1/showthread.php?5519-Post-curing-of-epoxy
