Would anyone here mind offering a little consultation on my Design Hydrostatics report from Delftship? I have never designed a boat before and this one is modeled after a big boat purely by pictures and the general dimensions. It seems the file is too large to attach so if you wouldn’t mind helping out please email me at Millrtme@comcast.net Subject: DELFT
Thank you much.
Millrtme,
You might also ask the guys at the boatdesign forum.
http://www.boatdesign.net/forums/forumdisplay.php?f=12
Mike
Well no luck over at boatdesign. I am starting to understand a bit (I think) Here at the numbers from the report if anyone is interested.
Design hydrostatics report.
Designer
Created by
Comment
Filename E:\Bounder\Scale Hull Rev 1.fbm
Design length 55.000 ft Midship location 27.500 ft
Length over all 55.000 ft Relative water density 1.025
Design beam 14.400 ft Mean shell thickness 0.0000 ft
Beam over all 14.328 ft Appendage coefficient 1.0000
Design draft 3.000 ft
Volume properties Waterplane properties
Displaced volume 487.26 ft3 Length on waterline 55.000 ft
Displacement 13.919 tons Beam on waterline 11.452 ft
Block coefficient 0.2051 Waterplane coefficient 0.5683
Prismatic coefficient 0.6144 Waterplane center of floatation 22.155 ft
Vert. prismatic coefficient 0.3609 Entrance angle 12.735 Degr.
Wetted surface area 507.39 ft^2 Transverse moment of inertia 3624.7 ft^4
Longitudinal center of buoyancy 25.357 ft Longitudinal moment of inertia 76821 ft^4
Longitudinal center of buoyancy -3.897 %
Vertical center of buoyancy 2.339 ft
Midship properties Initial stability
Midship section area 14.419 ft^2 Transverse metacentric height 9.778 ft
Midship coefficient 0.3338 Longitudinal metacentric height 160.00 ft
Lateral plane
Lateral area 74.386 ft^2
Longitudinal center of effort 30.112 ft
Vertical center of effort 2.257 ft
The following layer properties are calculated for both sides of the ship
Layer Area Thickness Weight VCG LCG TCG
ft^2 tons ft ft ft
Layer 0 891.94 0.000 0.000 3.078 25.165 0.000 (CL)
Sectional areas
Location Area Location Area Location Area Location Area Location Area
ft ft^2 ft ft^2 ft ft^2 ft ft^2 ft ft^2
0.000 1.663 11.000 9.624 22.000 14.453 33.000 12.774 44.000 5.955
2.750 3.419 13.750 11.224 24.750 14.671 35.750 11.407 46.750 4.166
5.500 5.542 16.500 12.607 27.500 14.419 38.500 9.701 49.500 2.582
8.250 7.704 19.250 13.744 30.250 13.763 41.250 7.838 52.250 1.226
