Be able to compare apples with bananas is not easy.
it’s even difficult to tell if a boat is simply better or worse than another and, in many cases, the outcome of the comparison will depend on environmental conditions as well as by different design choices
Before we talk about models is perhaps appropriate to try to figure out what are the most reasonably foreseeable footy race conditions
Our models, you know, are small (very small. )
skippers must been within 50 m from them to be able to see them without a binocular
footies , by force of circumstances, will sail (at sea, or on a pond) near the shores
On the ground, usually, there are trees, houses, walls and other junk
Which means that the wind, in the majority of cases, it will be very disturbed, the direction and intensity annoyingly variables
Races in stronger winds were those of 2008 and 2009 in Liverpool ( gusts around 40/50 km / h - if I remember correctly)
During the races in wroclaw (2010) and Constance (2011) the wind was, I think, no more than 10/15 km / h.
This summer in Sestriere was the strongest wind around 20 km / h
So I think it’s more likely the windwill be between 10 and 15 km / h
But the strongest wind with which you can race is much stronger, and I think the English friends can give us some information more precise on this point (50 - 60 km / h?)
As regards the waves, however, in most cases the footy are racing in small ponds where the waves do not exceed 10-15 cm.
In Konstanz, unfortunately, the competition was on the lee side of a large lake and the waves were a little bigger and annoying.
In any case, the relationship between height and length of the waves, as usually happens was around 1:10 / 1:20, much more smoother than “cartoon” waves Claudio has posted here few days ago.
The effect of the waves was only to increase hull pitch , but did not cause any “pulse” of the wind.
Both in Konstanz in water there were a lot of debris and sometimes huge weeds (more than a meter long)
conclusions:The race course will most likely be as follow :
Wind from zero to more than 40 km / h
average wind speed between 10 and 15 km/h
Intensity and wind direction often changing due to the aerodynamic “noise” around obstacles (houses and trees)
Waves , usually very small and not “breaking”
In the water often, but not always, there will be garbage floating which will end up in keels and rudders
Often, but not always, ducks, and aggressive swans will be close to our small boats
This seems like a necessary starting point of before talking about displacement ballast and rocket science
Flavio
