I received a couple of comments back from some who have pre-viewed the idea - so will include them as <font color=“red”>“things to consider”.</font id=“red”>
Remember, this is an idea, and a theory - it has NOT been tested, trialed or prototyped. Thought I would post the comments and thought and let you engineers - or “wanna-be” engineers pick it apart. A little bit of actual theory converted to drawings instead of words - hopefully easier to understand.
<u>THE CONCEPT:</u>
Instead of moving the keel <u>AND</u> the bulb, thereby losing lateral resistance, and having to add yet additional underwater appendages (more drag) my idea is to move ONLY the bulb. The original keel - or same basic keel (foil) remains as provided in the kit, or modified slightly. The keel “blade” DOES NOT MOVE. It remains in vertical position; it eliminates the need to add more appendages under water to recover lost lateral resistance; it reduces the “swing weight” of the assembly, and it allows smaller thru-hull fittings.
Since we are only moving 3 lbs. (approximately) according to Doug, the need for so much mass (keel) to support the bulb when tilted is questioned. Also, moving a rod sideways in the water takes more energy, servo strength, and power than moving a round rod sideways. Kind of like trying to push a canoe paddle sideways through the water. With the paddle blade at right angles to the blade movement, the thin paddle blade easily moves to the side. Turn the blade so the flat surface of the blade is pushing against the water, and there is a heck of a lot more resistance. Same with my keel idea. Moving the keel sideways through the water creates resistance (duh ! - Like lateral resistance) whereas moving a rod sideways creates very little resistance.
The drawings show the bulb supported by a rod, but swinging through the center of a slotted keel. <font color=“red”>SUGGESTION</font id=“red”> from pre-screeners of the idea suggest a possible change and moving the rod to the leading edge of the keel. This eliminates needing to slot the keel for rod movement, and any turbulence or drag induced by the keel slot. A concern about turbulence by a round rod was also voiced. I cannot speak to that, although, if of concern, the leading edge of the rod “could” be shaped like the leading edge of a foil.
The rod (approximately 1/4 inch to 3/8 inch diameter) has a cross rod that acts as fulcrum point. It is housed within a set of fiberglass (or carbon) fabricated plates. One goes on the bottom of the hull, the other on the inside of the hull. The small cross rod is supported and rotates in this thru-hull fitting. <font color=“red”>SUGGESTION </font id=“red”>- does this require a bearing surface? - <font color=“green”>RESPONSE: </font id=“green”>maybe not. It would be water filled, not a dry rotational rod. It is relatively slow speed rotation. Also weight is very little compared to big boats. And if there was a desire to have some sort of a bearing surface, nylon, delrin or similar high molecular material could be used to reduce friction.
On top of the thru-hull, a rubber grommet could be used. Smaller than a baby-bottle nipple or condom, these are often used in thru-hull steering assemblies on fast electric or gas r/c hydros.
I have included two concepts for winch control - a HiTech 815 BB arm for fast trim - but not sure about power, or a HiTech drum winch - slower, but line could be multi-part purchase to increase power. Either winch is less than $80.00 U.S. (unlike the Guyatt drum winches now upwards of $150.00 U.S.) If the drum winch is adequate for the needed job, depending on where the pin is placed to link the arm to the canting bulb rod, the amount of tilt could be mechanically controlled. In light air, it could be a very small throw, in heavier air a larger longer throw (more degrees of tile)!
Again - a lot of ideas - but needs input and thoughts from others. Go to it. Any comments made <u>WILL NOT </u>be considered personal. Criticism is expected and invited. Just be prepared to back up your arguments or comments with fact or with your views. - Although there is nothing wrong with just saying <font color=“brown”>“I Don’t Like Canting Keels!” </font id=“brown”>?. Cause I’m not so sure I do either - at this time.
<font color=“purple”>General “concept” and side view of idea.</font id=“purple”>
Download Attachment: [
smCK.jpg](http://www.rcsailing.net/forum1/data/Dick Lemke/200412513384_smCK.jpg)
9.64KB
<font color=“purple”>General view (3D) of swinging rod/bulb with fixed keel</font id=“purple”>
smCK1a.jpg](http://www.rcsailing.net/forum1/data/Dick Lemke/2004125133836_smCK1a.jpg)
13.95KB
<font color=“purple”>Drawing of possible thru-hull fitting plates and fulcrum support.</font id=“purple”>
smCK1b.jpg](http://www.rcsailing.net/forum1/data/Dick Lemke/2004125133912_smCK1b.jpg)
16.35KB
<font color=“purple”>Concept for arm winch attachment</font id=“purple”>
smCK1c.jpg](http://www.rcsailing.net/forum1/data/Dick Lemke/2004125133943_smCK1c.jpg)
11.01KB
<font color=“purple”>Concept for drum winch with line control attachment.</font id=“purple”>
smCK1d.jpg](http://www.rcsailing.net/forum1/data/Dick Lemke/200412513402_smCK1d.jpg)
16.36KB
