He chortled in his Joy.
Well I may be over-reacting a bit; you have told me millions of times not to exaggerate:D
I’m happy that the AA rule has gone. There was nothing wrong with the firm intent of it - to make Footying widely available in the world so that no-one was excluded by poverty or unavailability of batteries.
I believe that I am the single person most affected by the rule:confused:
I have built two Footys which are sized exactly and specifically to fit AA cells, ZBF and Sloice. On hearing about the decision of assembled Footy voters I rejoiced and immediately finished Sloice (pics attached If I can winkle them out of the camera)
Sloice with “bustles” fitted and rough carved. The Hull is the Balsa meat in the sandwich which has a “sanderson slot” to allow nearinfinite adjustment of the mast and keel position
Not TOO wide
Borrowed sail; mast needs to be further forward:D
Exactly a year ago I wrote a screed about the options for powering Footys, and have just re-read it to see if it might help now with information about the options - attached.
There is no crying need to change away from AA cells for the current generation of boats - I would strongly suggest dropping to three primary cells (Energiser Lithium or duracells) to reduce weight.
My view of the likely effects of the rule change?
Short term: People will fit lighter batteries in their boats - possibly 4AAAs , 3AAs or one LI-po or Li-ion cell. Boats will float higher, bob more and may sail a little better. The option of replacing the weight saved in the bulb will slightly improve stiffness and buld ratio, making a slightly better Footy
Medium term (1 to 3 years)
Boats developed to suit new rules - which effectively mean that batteries, like servos before them become VERY small limitations in design or stowage.
I do not expect anyone (except possibly myself) to use single 100MAH lipo cells (0ne gram; smaller than a stamp) and change them for each race:D:D
Long term
Footys will be able to develop in the sleeker, mini-marblehead direction
Wide, Chumbly, footys will continue to exist (some with AAs in) and compete and win
And you, what do you think?
andrew
