well there we go…
Finally, I got my 2nd dremel…one sitting in Europe…
What “tools” would you recommend for a noobie builder??
I have now:
the Dremel Multi Pro , and siper accessory kit
-Wis
well there we go…
I have now:
-Wis
I love the Dremel jigsaw, it has a driver for a sanding disc also. Xacto hand saws and lots of no. 11 knife blades. The most important “tool” is super glue debonder. Clyde
What materials are you going to be using Wis? My first decent model making tools were a modeling knife, razor saw and a cutting mat, but I started building with balsa…
Luff 'em & leave 'em.
I ll work probably on plywood or/and balsa as for now…cant see me working on anything else NOW…
-Wis
wis this is about all you need, for thin balsa and ply.
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXKY05&P=ML
If you’re going to be cutting thick ply you will need a real saw.
-Dan
Dan,
Soon its Xmas…you know what to do [;)] its on my wish list, thx Santa
-Wis
Wis
I think you need to talk to your wife about that.
-Dan
<blockquote id=“quote”><font size=“1” face=“Verdana, Arial, Helvetica” id=“quote”>quote:<hr height=“1” noshade id=“quote”>Originally posted by wismerhell
well there we go…
I have now:
-Wis
Tools I use almost every day (and wouldn’t be without):
Bandsaw
Disc sander
Cordless drill
Swann Morton knife + No. 11 blades
Various steel rules in different lengths
A long ally sanding block
A Granite worksurface… it’s very very very flat
A dozen different types of clamp
Tools that are almost indespensable:
Pillar drill
Fretsaw
Metal lathe
Wood chisels
Block planes
Bench Grinder
Tools that are nice to have:
“Dremmel” (mine isn’t)
Jigsaw
Angle grinder
Not to mention pliers, screwdrivers, etc, etc, etc.
Tools I think I need:
Circular saw
Wood lathe
Planer thicknesser
I’m pretty sure there’s many more to add to the list… My advice… just buy them!
Philip Rawson
I have a drill, a sander and a small collection of hand tools. My work bench is the dining room table in the dining/living room of my one bedroom condo with white rugs.
As long as you don’t use CF most of the dust is white so it doesn’t really matter.
Don Case
Vancouver Island
<blockquote id=“quote”><font size=“1” face=“Verdana, Arial, Helvetica” id=“quote”>quote:<hr height=“1” noshade id=“quote”>Originally posted by Don
Now that’s an attitude I like… I gave up vacuuming the house ages ago, 'cos there’s so many shavings that it just clogs the vac. cleaner… and I don’t even work in the house.
Philip Rawson
XMAS to all of you
for MINI TOOLS I use these:
see my web Site:
THE SAILOR
http://the-sailor1.tripod.com/index.htm
THE SAILOR
The belt on the vacuum broke so I won’t be doing the rug. So one of my tools is down.
