Build Log: IOM
IOM 681
Graham Bantrock designed hull “Vivid”
What started out as 2 blocks of Dow Corning 4" thick insulation foam. Is now a male plug. Thanks to a good friend for his computer and CAD/CAM/CNC machine, he working on a goth plug.
my plan is to do what I’ve done on the Albacore(bilge rat) 6,4,2 ounce glass
I just finished a hull for a 1920’s powerboat(Augusta) using the same glass method. and the bare hull prior to finish sanding/paint is 10.4 ounces… and its 38" long
being that the iom hull is much skinnier and not nearly as much free board… getting the bare hull with no deck close to 225-250 grams should not be a challenge.
need to order some more glass before I start glassing though…hate to run out…:slight_smile:
had enough glass for Vivid Hull #1
What would be an ideal weight for a bare IOM hull ?
I’ve been seeing a complete hull with deck and fittings around 500 -800 grams… I figure if I can come in at 225-250 for the hull, adding the deck and fittings should put in the 500-600 gram range…
old info, but data is data…
http://www.anderswallin.net/wp-content/2003_07/IOMWeightBudget2003july.pdf
I put in the transom and bow tonight. so I should have some pics and weights of the bare hull tomorrow…Fingers are still sticky…
Good and fast work Marc. Thank you for taking the time to share this build with us.
I am puzzled. How did you come up with a nice and smooth closed transom and bow hull from your opened ends hull? Maybe your pictures are just too low-res to understand your work. I imagine that you preformed the bow and cut the transom out of a plat f/g plate. But your joints seem so perfect!
Sylvain
Sylvan,
I’ll take some closeups this afternoon. it is not nearly as purty as you think… i used some painters tape to close up the ends from the outside and than laid up 3 layers of glass from the inside… I then used some west 105/206 with some micro light filler 410 on the inside to as a fillet. I will need to mix some west with the low density filler 410 for the outside to fair the joints. the bow joint will be covered with a bumper. have not cut the bumper yet…
in all honesty getting the hull shape is usually the hardest part, but having someone who has access to nice equipment has made life a bit easier and a lot cleaner. having to sand the foam is one of the bigger PITA’s
235 grams
keel fin, keel bulb, keel trunk…the fun really begins…
bow and stern…see not real purty when you look close…the stern will fill and blend nicely. not sure about the bow…it may get cut out and redone…
Looks like work has slowed a bit…
unless you want pictures of sanding dust… : ) holidays have slowed me down a bit.
I have 3 dinners in the next three days to prep for…
I do have the deck plug ready to lay up. I was hoping to have another hull to lay up at the same time…but someone is slacking in that department…
Maybe when you come over for the club meeting we can lay it up…
taped up the deck and laid out 6oz, and 1oz glass…and also did some work on the hull plug… had a few nicks that I needed to smooth out…
Hi Marc,
You say your hull is a Bantock Vivid. Is this a new design? I can’t find it on SAILSetc site.
Tony
tony…
It is Grahams Hull. the vivid is a modified Fraktal. You are correct it is not posted on his site.
it has less wetted surface, and a narrower transom…
Hi Marc,
great work - does the overlap in the packing tape you use on the form not leave its mark on the epoxied form once removed ? do you use any wax on top of the packing tape ?
Gilbert
it does leave a line the thickness of the tape. does not appear on the outside of the glass…
remember I an not building a mold. i’m using the male plug to make a hull…
after I pull a few more hulls off the plug, before its destroyed I will make a female mold.
I have done it without wax, and it releases fine… but I have no other basis for comparison. Ie if waxing makes it easier or not…
thanks for your response Marc, In an earlier post there was a question about weight. Here is a newsletter from Seattle IOM club where you can find some handy information about weight. see pages related to the built of the SKA design. If it helps.
Atb,
G.
thanks for the email link…
Hi Marc, any development on your IOM ?
I’m gonna try your method of the packing tape to take a mold of the foredeck of an IOM before I cut it open so I can replace the piece I’ll cut out - fingers crossed !!! :shake::shake:
no not much…i cut out the transom and the bow. I was not happy with the the way they tuned out. holidays, the wing project, and an classic motoryatch build have kept me pretty much everywhere but with the IOM…
the other thing you could do would be to use saran wrap I have used it with some success… but it wrinkles so easily…
I did put an update on my post re the jib attachment point but it worked very well with the packing tape as you suggested. Brilliant…
Oh and Merry Christmas to you
Gilbert
