I thought I would start a new thread where ideas and plans could be posted for a potetial small 65cm/25-1/2 inch multihull class.
Given the interest in the RG-65 monohull class and it’s size making for easy transportation, I thought I would take a shot at a down-sized GHOST TRAIN in similar size to see what problems I might face.
The attached is an Acrobat file of the general lines of the GHOST TRAIN trimaran, which could be built using balsa-over-stations tempates; or it could be built using foam, and covered with epoxy/glass and the foam removed. It may require more displacement, and possibly a bit of weight for inertia when tacking in stronger winds, but I need to get one on the water to see.
If you decide to try, you will need to enlarge and print the drawing to 100% and it will need to be printed on a wide-format printer if you want it on a single piece of paper. My full size is approximatly 17 inches high by about 30 inches wide. If your printer has “tile printing” capability, you can probably print directly to normal size paper and tape together.
I would make one change when building - instead of splitting the hull/floats vertically with a left/right side - I’d split it horizontally and build a lower adn upper half hull. Makes installing radio gear and internals much easier.
Please post if you decide to try one and how well it sailed when done.
