system
November 6, 2004, 2:41am
1
some technicl question here:
I am willing to use 4 AAA NiMH 800Mah in my Micro Magic…I DO NOT NEED 6v!! so 4.8v is enough…now a question…how do I solder them together?
Any ideas, advices, anything please.
Wis
A few pics of my 4,8 V battery packs for my Micro Magic.
http://www.rcpics.net/img/42166i have made this batterypack separated so i can put the battery around the finbox
http://www.rcpics.net/img/42165 A picture of the conection between the cells just a small electric wire.
http://www.rcpics.net/img/42164A normal battery pack for my Micro Magic
There are more photo’s of my Micro Magic at:
http://www.rcpics.net/member/Ned31
regards
Jeroen Koeleman
system
November 6, 2004, 4:18am
3
thanks…what solder did you use 30watt or more?
I like the idea of the separate battery pack…will do some.
Thanks…oh and another question [;)] what cable did you use for connecting batteries? what diameter I mean?
Wis
I use a 100 Watt solder.
the cable I use has a diameter of 1,75 mm
Jeroen
system
November 6, 2004, 4:35am
5
For the rudder I use a hs-50 or something similar.
For the sails I use a hs-225MG BB. The most people in The Netherlands are using this servo.
if you have got more questions just ask!
Jeroen
Wis
I seriously recommend you don?t use a soldering iron under 75 watts. Experts will tell you that you can get away with 50 watts, but these are the same guys that make 20 packs a day and sell them over the net. Because trust me I have seen what happens when a battery ruptures.
That being said, if you pick up a good 100 or 150 watt soldering gun (around 100+ watts they are guns not the little irons you see used on computers), and you prepare properly, it will be an easy task.
These links will help
http://members.aol.com/davthacker/cellsoldering.htm
http://www.rccaraction.com/rc/articles/build_battery.asp
http://www.offshoreelectrics.com/how_to_build__battery_packs.htm
http://www.batterieswholesale.com/battery_tips/assembling.htm
If you have questions let me know.
-Dan
system
November 6, 2004, 9:21pm
8
Jeroen,
Thanks…I almost chose the same one, just the one you use for the rudder is even lighter.
Dan,
Nice links…now rock and roll and try
Wis
