<blockquote id=“quote”><font size=“1” face=“Verdana, Arial, Helvetica” id=“quote”>quote:<hr height=“1” noshade id=“quote”>Originally posted by Matthew Lingley
This idea has been floating around a while I know, but despite my original dislike for the idea I think it is possible to make a reasonable pefromance cat using an off the shelf IOM rig.
Matt, Cougar & Others interested in the MultiONE …
Tonite I did a bit of research and found some interesting size comparisons. You all might want to keep these in mind when you start promoting a MultiONE concept.
RIG HEIGHT:
Mini40/F-48
Maximum #1 = 2085 mm or 82 inches.
#2 = 1885 mm or 74 inches
#3 = 1685 mm or 66 inches
#4 = 1485 mm or 58 inches
(From rig tables provided with GHOST TRAIN drawings)
Recommended rig for wind strengths:
#1 Less than 12.9 knts.
#2 Less than 15.4 knts.
#3 Less than 17.3 knts.
#4 Greater than 17.4 knts.
OK?
Let’s move to the concept boat of Matt and Cougar - where they reference a desire to use an IOM rig on a MultiONE. The IOM rig is listed at 1.7 meters, 1685 mm or 66 inches. This is identical to the #3 rig of a Mini40/F-48.
NOW -
Look at the rules for the MultiONE and you will see that the maximum mast height above deck is 85 inches or 2159 mm! This is a taller mast than allowed on the Mini40/F-48 !!!
So I guess my question remains to those concerned about capsize of the larger multihulls … why wouldn’t you drop back to one of the smaller rig sizes #3 or #4 and learn to sail with the boat powered the same or slightly less than the IOM? Again, my point - I guess is that just because it is allowed, everyone feels they must use it, but then comment on how much the boat capsizes. Gee!
Now -let’s look at the MultiONE and IOM with the same rig. (a #3 for example)
Both boats have same length.
Multi has wider beam and less tipping
Multi (probably) weighs a bit more than the IOM
IOM has a lead keel
Can we assume they then weigh roughly the same?
So now we have both boats of comparable sail area and rig height. Which one wins? If all else is the same, could we suggest the multihull might because it has it’s sail vertical to water and the IOM would be sialing at a heeled angle. BUT, how high can a multi point compared to an IOM? and If the multi is a bit slower tacking, would the IOM win? And if by chance the three hull weight is still less than the IOM with it’s lead, could the multi win? Ahhhh - we could go on with the what-if’s once again. It would be so easy to get a few multi’s built, weighed and then race them against the IOM with comparable sail power. Anyone want to bet that IF you could keep the multiONE on it’s feet using the #1 rig that the multi would blow the IOM away?
I would be interested in seeing someone build and race an IOM just to see a comparison. Anyone willing?
Dick Lemke
F-48 #US-06
MultiONE #US-06
Class 3 Landyacht #US-196
