I found this old sailboat kit at a yard sale this past summer. I knew it had potential to sail using mini Rc servos. However, having not set-up one with such a small cabin I would like some suggestions from more experienced builders.
The sailboat has a length of 15”. I rigged the jib to be set using the Bowsie. It is the servo set up for the main that I am not sure about, which is where your help is desired.
If you google on “Footy Class” you’ll find a wealth of information on RC for boats this size. I would suggest a two-hatch solution, a removable cabin for battery access and a larger, screw-down hatch holding it for occasional access to “the works.”
