The F-48 - (not a Mini40 - don’t want to upset our French readers) is still in building progress. It was sidelined for slightly more than a year while I built the MultiONE (1 Meter). Then the stroke, and hopefully now back to building. A possible contract builder is in the works as well (see multihull area of the forum) so it is now a question of proceeding with what I started - or see what he puts out and buy into that.
Even at 1 Meter, the space taken up can be a problem. Sitting on the driveway next to the family car, you can see it certainly takes up more room than a “Footy”![:D]
Download 1 Meter Attachment: [
Nexttocar.jpg](http://www.rcsailing.net/forum1/data/dick lemke/2005713214239_Nexttocar.jpg)
17.29KB
and if it still remains a problem, there is always the old, standby truck. (Recently replaced with a four door 3/4 ton, and Damn the gas prices!)
Download 1 Meter in Truck Attachment: [
smInTruck.jpg](http://www.rcsailing.net/forum1/data/dick lemke/2005713214528_smInTruck.jpg)
34.76KB
Now, “if” I was required to transport in a knocked down state - a screwdriver would result in quick disassemble. Each side shroud bridle wire ti attached to a beam end, and secures the float inside the cross beam tube. Remove the 4 screws, and the floats slide off the crossbeam.
Download Crossbeam-Bridlewire Attachment: [
smBridlewire001.jpg](http://www.rcsailing.net/forum1/data/dick lemke/2005713215654_smBridlewire001.jpg)
10.82KB
Then the cross beam slides out of the main hull supports. You now have a main hull, two floats, and two cross beams. Remove the daggerboard and the rudder (set screw) and take the main and jib off the mast connections. I roll up the main parallel with the full length battens and the jib is also rolled up. (Around a cardboard tube) The mast for the MultiONE is a bit of a problem at just under 70 inches, but will fit across the back seat at an angle. If traveling short distances or alone, I only need to remove the mast, as the entire trimaran platform will sit on it’s side in the back seat of the car (or truck). Can even leave board and rudder attached - but I know I am playing the odds with the rudder left on. Sooner or later it will be “wacked” into the car door frame if not careful. My little old (1990) Ford Escort has a hatch back and fold down rear seats so again, remove mast and lay on flat floor area of the Escort.
Now for the bigger F-48 I envision the same process but with slight longer hulls - 48 inches instead of 39 (or 1.2 meters instead of 1 meter). The big question will be the mast. My current mast is slightly less than 8 feet in length, having been shortened to fit the boat after this photo was taken.
Download F-48 Mast Attachment: [
smF-48HTWfull.jpg](http://www.rcsailing.net/forum1/data/dick lemke/200571322351_smF-48HTWfull.jpg)
13.42KB
This mast has been sleeved and is a two piece mast, so I need to loosen the diamond wire and then slide the top portion off the bottom portion. The remainder would travel much like the MultiONE.
Finally, a future build I want to try is a 2 Meter “monster” and due to it’s size, the thing will need to be broken down and carried in the back bed of the truck, or perhaps a special trailer like this one from one of you “Crazy Down Under” guys! [:D]
Download 2 Meter Attachment: [
Image11sm.jpg](http://www.rcsailing.net/forum1/data/dick lemke/200571322740_Image11sm.jpg)
21.34KB
Anyway - there are a variety of ways to breakdown and travel. Assembly on site is only a bit longer than a monohull, as they still must rig too. (“Footy” excepted, of course) I also have sketches of a mast carry case I devised from two pieces of roof (eaves) “gutter” or rain-trough, a couple of pieces of pine, a handle, some hinges and miscellaneous screws. Mine holds masts with 4 inch wide spreaders as well as the rolled up sails. Depending on the length of the masts you can build to suit and just might need an additional hinge or two. Kind of like carrying a fishing pole case. (Which, by the way works - but is kind of spendy).
That’s about it for traveling with a multi.
[:-mischievous] We now return you to your regularly scheduled broadcast. [;)]
Dick Lemke
F-48 #US-06
MultiONE #US-06
Class 3 Landyacht #US-196
Minnesota, USA
