From the US AMYA Class Description Page:
The Footy class is a Development class (Development classes are now termed Open classes as defined by ISAF Equipment Rules of Sailing) which provides lots of flexibility for builders, since anything not specifically prohibited or restricted by the class rules is legal. So the Footy is a perfect class for beginning and experienced boat designers alike. New ideas can be developed quickly and inexpensively.
A Footy class boat must fit in a box 12"L X 12"D X 6"W. Primary rig configuration is unlimited. Radio control is two channels only, and must be powered by 4 AA batteries. Several different hull designs have been developed, and Footys have been built with lateen rigs, gaff rigs, swing rigs, and genoa jibs. The small size makes scratchbuilding fun, but full kits, partial kits, and plans are available for less ambitious skippers.
A Footy is a great boat for all anyone. A competitive Footy can be built for less than $100, is easily portable, and regattas can be held in the smallest of ponds; even in your backyard swimming pool!
[LEFT]Since the class has yet to be recognized as an international class, now would be the time to have a vote on this, rather than waiting until even more are built. Back when the rules were proposed, I recall specifically pointing out that class rules in a development class should be minimal with only physical characteristics identified more to control size - and that any other rules should be avoided as they restrict true development efforts. To this end there was a great box rule to identify the physical size of the boat, and a mast height and keel depth pretty much defined the maximum sail area and required righting moment needed so that was self limiting by virtue of how much physical sail material one could put into the air and still have stability in a breeze.
Then the folks started “mucking about” with the “other rules” …
Specific battery size
Number of radio channels
Outboard versus inboard rudders
The first two in an attempt to help control cost through weight perhaps? Yet, unlike the a few other classes, was there no thought to eliminating carbon and allowing only wood or fiberglass in hull construction - which in my opinion were fine since the class was advertised as “developmental”.[/LEFT]
Looking at the above with personal commentary:
Battery type/size. An issue that isn’t … Cost - the most expensive batteries cost about the same as a yard of carbon, so cost cannot be an issue, if carbon and it’s associated cost isn’t an issue. Safety - sorry but a piece of burning plastic only 12 inches long in the middle of a pond somehow fails to connote a safety issue in my mind. Once out of the water, batteries are unplugged. This is kind of a personal safety thing… since safety belts for wheelchair bound skippers, or Personal Flotation Devices for those skippers walking on shore who “could” fall in a drown are also missing. One wonders how far an organization is going to go to “protect” us from our own stupidity?
[LEFT]Radio channels? - Cost issue - then ban the tiny digital servos, otherwise the number will be self-policed by those wanting a lightweight boat. Why put in three if two will work and be lighter?
Outboard versus inboard rudders - the box rule was already in place, but some couldn’t understand the concept of the boat fitting INSIDE of the box so a slot was cut in the box, and then a ton of time was spent discussing how big a rudder could be to extend to the rear. If transom hung rudders were legal, then it seems sort of simple, they must fit inside the box. Want a longer waterline to be fast? Put the rudder under the hull to gain maximum hull length.
[/LEFT]
A restricted development class really sounds good, but as someone noted, the horse is out of the barn - so it would seem (to me) logical that less restrictions are possible, but more restrictions such as minimum weight will be hard to impose without making a few (or a lot) of people really upset.
As for that supposed $100 cost - perhaps the word “home built” might allow that statement to be more widely accepted.
Just some personal observations that are easy to make since there is no vested interest for me which way this is resolved.
