Please bare with me as this is some group think out-loud. Hope to get some help from you-all figuring out the right set of ratios and fudge factors for the “Perfect NDC”
Here is the initial thought. Angus thinks metric. I think inches. Many different boat designs. Some boats fat, Some boats skinny. How to compare apples to oranges?
Now for the reference boat. Visualize a normalized circle of unit radus (1).
Top - At the top,represents sail area. There a TBD fudge factor that when mulltiplied times area = 1.
Bottom - This factor is the righting moment. Simply balast weight times distance from water line to C/L of balast times fudge factor to = 1…
Left - This is the waterline length divided by max waterline beam width times a fudge factor to = 1.
Right - Total weight divided by balast weight times FF to = 1.
I need someone to select a boat to represent the perfect boat/perfect circle so that T:B:L:R (Points of Circle) are 1:1:1:1. Other boat designs can be compaed to this boat.
Based on this reference boat, we can publish the following Fudge Factors.
…TFF
.LFF…RFF
…BFF
Thus, instead of a whole list of parameters, we could simply visualize an out of shape circle or four factors.
As the wind conditions change, it will be interesting to see what shape the circle takes for the winning boats?
The four points suggested are just to be considered a starting point. Suggested changes are encouraged and hopefully a useful model for boat performance can be developed.
If this should be a separate thread, that is fine w/me.
FastFrank/No Relation to Fudge Factor
