> 10 minutes/5 minutes before I’m in the water
This seems reasonable. Not a concern for the hull plug, but I guess from now on I should keep close attention to every little details that will make it easier/faster lakeside. Oh well, a call to re-read for the zillion time all your building logs.
> providing no-one is asking me 100’s of questions like where is the motor?
My jaw still hurt on this one. :lol:
SHADOWS (2)
Ok, case closed. For better or for worst, I have now printed my shadow templates. I don’t think the overhang steps are that critical as I can easily (well, time will tell) create a temporary guiding edge for the stringer and the first strip of balsa with a simple piece of wood pressed by hand under the shadows. Bottom clearance for sanding and glassing are privileged. I reworked a bit the hollow inside the shadows, at the level of the first plank. It will be easier to use spring clamps there. I also tapered the legs “à la Alan” if I ever want to try latex lamination. Only the baseboard will need to be trimmed in this eventuality. Some of the white off cut portion will make the female cradle on a second baseboard.
I did a thorough search for 1/8” (3.18mm) plywood around here but found nothing readily available. There is plenty of luan and hardwood though, both very cheap. Luan looks a lot like flat door panel (two sheets with an inside core of something) and maybe it is. I had some experience with it in the past and I recall that the edge of the panels were friable. So I choose hardwood (seems like a very dense cardboard compression, like the one we have at the back of bookshelves cabinet, only thicker, harder and flat on both side). Goose, in its “ETNZ IACC120 Dual build”, reports that this material was not taking CA glue properly. But thanks to his “in-house testing facility”, we now know that Titebond III is working well with this material, the only drawback being the drying/curing time. Maybe I am still a bit naïve about planking a hull, but this doesn’t bother me.
I will use Claudio’s proposed configuration for the frame. At first, I was racking my brain to find a way to bevel properly the shadows along the natural curve and not in angular steps. But then I figured that only the tip of the support edge must be precise (undiminished/untouched). I should only and relatively loosely bevel the potential interference that would prevent the natural curve of the planking and it won’t matter if the bevel doesn’t perfectly match the natural curve. Seems more reasonable!
BALSA PLANKS
The common balsa sheets in North America are 36” (91,4cm). Since, as possible, I didn’t want to bother with joints but still wanted the working easiness of balsa, I needed to find some of the less common 48” (122cm) length. There is plenty online but it didn’t come that cheap if you add shipping. I had finally resolved to cut myself some stripe from wood I already have.
Without any conviction, I eventually dropped by our local hobby shop. I remembered from many years back that the old guy didn’t had much stuff there and everything was pricy. No surprise, the guy was even older and he only had costly 36” stripes (compare to this Internet era). But he was intrigue by my request and we chat a little. At one point, he got up and went to is back store (I think he lives there) only to come out with 6 balsa planks of the desire length, “from my personal supply” he said, “will this help you?” Well, of course. They were full of dust and a bit wavy at the edges. Very flat though, nothing that couldn’t be straightened by a clean cut with a metal straight ruler. Because of my hesitation, he offered them to me at a third of what would have been a good price!
Shadows 2.50$CA, planking 10$CA and the baseboard and angle brackets for nothing. That’s about 8,95€ for you guys in the birth land of the IACC120. Not too bad a start.
…AND SOME HARDWARE
I also found spring clamps at a good price… well I think. 48 x 2.5” (6,35cm) and 12 x 3.25” (8,25cm) for 14$CA at www.widgetsupply.com (great service BTW, and cheap shipping fees). Then another great finding, a scroll saw in good shape for 15$ in a garage sale. I know that I could have done without these, kind of luxury in my conscientious budget, but I think this will make my wannabe-hobbyist life much easier. A way to make sure I give me a chance to be in for the long run.
Since I am on a good roll, maybe I should look around for a cheap bargain on Dick’s indoor pool idea. :lol:
Finally! The real work can begin.
