Hi Michael -
When I arrived at the sailing site, Dave Goebel was just unloading his covered trailer. As we carried the bits and pieces of the Spinnaker 50 around the house and down to the lake, Chris (the F3 owner) was bringing the F3 from the house (as I recall).
The construction method for the tip probably follows Doug’s instructions elsewhere for building your own curved rod of carbon fibers, laid up inside a polyethelyne tube. After cure the plastic tube is stripped away and the bent/shaped carbon rod is left. (encapsulated recap of Doug’s suggested process).
If you look at the second posted photo, right behind the hand holding the mast, you will see a plug that was part of the tip rod. It was glued in place and was there to center the tip rod in the top of the mast, and also controlled how deep the tip was inserted into the top of the mast. This “plug”, “stopper” or whatever you want to call it would have been out near the end of the crane (rod) if we would have tried to insert it in the opposite direction.
Note also that the Spinnaker 50 (same rig design per Doug) did NOT have this big of a wrinkle at the top - indicating (once again) that the issue was and still is being ignored or explained away. It is simple - there was something wrong with the tip. Four of us tried rearranging and readjusting the thing without success. After the weekend, I sent photos to Doug explaining both the sail/wrinkle problem, as well as the issue of the wands being too short at first and only finding out after sailing the boat, that they could be adjusted.
Doug has already admitted he received messages from me and from Tony Johnson regarding the terrible looking rig/sail combination. In fact in an email to me, he asked that I not post the photo as there was something terribly wrong!
So now it is denial, but at the time he made calls to Tony to explain how to make corrections. What were those instructions?
What are we to believe … the sail/rig was of poor quality control, had a wrinkle 4 experienceed sailors could not correct, is documented in several different photos and different sailing venues (Florida and Minnesota) and that at the time Doug supposedly called to tell how to fix … or Doug’s most recent post where he writes <blockquote id=“quote”><font size=“1” face=“Verdana, Arial, Helvetica” id=“quote”>quote:<hr height=“1” noshade id=“quote”> <font size=“2”><font color=“red”>“This is just another case where you simply don’t know what you’re talking about!” </font id=“red”></font id=“size2”><hr height=“1” noshade id=“quote”></blockquote id=“quote”></font id=“quote”> and continues to deny there was a problem.
I guess I just want to know which lie …errrr … post I am to believe? I will chose the former, since it is proven by a variety of photo shots, whereas the latter post (quoted here) is Doug reverting back to his old posts where everyone is wrong, doesn’t understand, etc. etc. because he damn well knows the sail and that specific wonderful, innovative, Wing Tip Rig was a piece of junk!
And the reason behind all of this - to dispute the sugar coated claims being made about how a Wing Tip Rig will aid in tacking… hogwash. To use one of Doug’s sayings, (with all due credit afforded to Doug) - he “Couldn’t be more wrong” and “This is just another case where he simply doesn’t know what he’s talking about!”
Isn’t it amazing that in spite of photos, witnesses, email messages, and even admitted attempts to contact us to explain how to “FIX THE PROBLEM” - Doug continues to deny there is a problem?
I would urge ANYONE currently doing business with Doug to be aware of possibly becoming the next victim of your own stupidity - and if you aren’t doing business I might suggest a serious consideration to keep it that way!
Oh - and if still in doubt - there is also another F3 owner that was very unhappy too, and he was slammed in public by Doug on this forum as well! Let’s not sweep him under the rug either.
As someone from overseas remarked - “this kind of stuff over here would constitute fraud !”
