<blockquote id=“quote”><font size=“1” face=“Verdana, Arial, Helvetica” id=“quote”>quote:<hr height=“1” noshade id=“quote”>Originally posted by NIMSS
NOT A PROBLEM as such…
Personally, I cannot see what difference whether the shrouds attach to the CROSS arms or at the normal hounds (70%). The windward shroud will always be under tension, wherever it is attached to therefore creating various forces…Okay, so the shroud attached to the CROSS arm(s) and will generate a force directed onto the bearing at the mast head - this bearing is man enough!
One thing that emerged from tests is that the s/s burgee rod was not long enough [spreading the load] or the c/f cloth/SP mixture was too weak - & therefore was pushed/pulled sideways out of the mast head.
I agree that by tightening the fore & back stay as well as the shrouds, forces are generated by this action into the mast head - depressing it, but the actual construction of the mast and the spreader/diamond wires will prevent a buckled mast.
Even though the mast is under compression, because the bearings are man enough, the mast will [as does] freely rotate.
I am constructing a more or less accuate drawing to show size.
NIMSS
You are correct that the windward shroud will be in tension. However, since that force is now acting at the end of a long lever arm attached to the top of the mast, it will induce a bending load in addition to compression.
You can proove this to yourself with a simple exercise. Get yourself a wooden dowel (or one of your carbon tube masts if you prefer). clamp the end of the dowel or tube into a vice so that it is held fairly solid. Tie a wire or string to the tip of the mast and pull on it from a point that would simulate the relative position of where the shroud attaches to the deck relative to the base of the mast (if you have a way of measuring the force, that is great) and see how much the dowle or tube bends. Now repeat that exercise with your cross bar in place. You will see that the bending is a lot higher for the same amount of force.
I’m pretty sure this is the cause of your failure (although you never really described the failure well enough in terms of location and failure mode to be sure).
If you want to keep the diamonds and the mast head shrouds, then you can do that. Simply have a single diamond stay with the spreader short enough to pass inside the shroud as the mast rotates. Take a look at rigs on some of the Vendee boats as they have a rig very much like this (rotating mast with diamonds and shrouds).
- Will
</center>
