Hi Phil,
I built mine from Depron, which bends a lo easier then balsa. but i will try to offer advice.
You are indeed correct it is a ‘double diagonal’ boat (diagonal, and up/down)
I did not use a former, and my assembly order was:
1- join the upper and lower side panels, along their seams.
2- join the lower side panels to the ‘keel piece’ or bottom plank.
3- fin in the flat forward bow piece, and the lower transom.
4- fit the upper transom, a rudder stock support piece (i didn’t trust my 3mm depron deck to carry all that load)
5- finally fit the deck. noting, i made the top of the keel extend thorugh the deck, for strength/stiffness.
NOTE i had to ‘bow’ the hull slightly to spring it open when fitting the deck.
In balsa my suggestion would be:
Make up a coule of foam or wood blocks as internal jigs
lightly dampen both faces of each panel.
Pull together at the seams, and hold with tape, rubber bands, spot tack of cyano etc, untill dry. this should give the panels about the right shape.
then finally glue properly when dry
Hope this helps
Scott
Razor 3 #284
Ranger #347
) I decided to take my sailboats out for a spin at the local lake. Took out my scampi, a 36/600 class and my Ranger Footy. Of course I had to bring all the rigs for the footy, so I could test which one would work best. I was able to test rigs B, C and D. Too windy for rig A. I shot some video from my cell phone so please excuse the quality.
