Question, what did the bend of the mast look like? With a tapered section, it might have bent more toward the top than it did toward the bottom so that your bend would be unsymmetric? I’m not sure with only one inch of bend over 63 inches that you would be able to see any sort of unsymmetric-ness in the bend, but maybe…
Will - I used an old belt to spread the weight over about 1 1/4 inches of mast section in the center. I specifically looked at the mast versus the stretched string and didn’t see enough of a difference to warrant a closer look. I measured what appeared to be the maximum deflection, and it occured right in the middle where the weight was hanging. It would be possible to subject the mast to a specific location bend/stress, but where would one place the weight? I went to the middle, since a mast without spreaders would probably bend there if one were to really clamp on the backstay tension. Somewhere there were calculations for identifying the location and amount of wind to generate “X” lbs. of force on the mast, but couldn’t find it right away to verify.
On the other hand, the guys using fishing pole rods, with thin, bendy tips would see a lot less force needed and a bend further up the mast. This is why I wonder how useful any kind of data will be from doing these measurements.
I have a double section mast for my F-48 that is just shy of 8 feet tall (does need trimming) and my guess is that I might see close to 2 or more inches in bend if I tried the same experiment. But on that one, I was already planning a set of diamond wires and spreaders to enable the mast to be stiffer than without. That’s the mast that currently has a set of “M” Class sails attached, but I’m not sure I would go with such high aspect ratios unless the winds are really light!
Back to a practical use of test info.
What if someone took my mast section for a slightly smaller boat. If you cut off the length from the small tip - or from the larger I.D. bottom, it might change the entire mast bend completely? I think I need to find the calculation info that I mentioned above. Somewhere, the owner needs to determine the amount of sail area he will be carrying, the strength of the wind in which he will sail, and use those “pounds” (kgs.) to select the appropriate mast and mast bend characteristics. Once that is done, then the sailmaker can tailor the luff curve to fit the mast bend.
Doesn’t make much sense to have a luff curve of 3/8 inch, because then you have to search for a mast section that will bend to that curve - but in what air?
After fooling a bit with this test and measurement, I can see where trying to pick a mast section based on deflection, might just add more confusion to the process, rather than to just grab any piece and ask sailmaker to make a sail to fit the bend.
DON - Test was done very carefully, as the case was raised on a container. The belt looped through the handle, and tightened just to begin to deflect the mast. Then the support was removed while case was held, and gradually the case was lowered to transfer weight to mast.
Since the mast was engineered as a professional cross-country racing ski pole, my guess is that in compression it was rated for perhaps 150 - 180 lbs. before it would deflect. For this reason, I felt safe with a 20 lb. right angle load to the mast - but still did it slowly. I had also thought about using a gallon can of paint, but it “felt” too light and I didn’t think it would deflect the mast tube enough to allow me to measure deflection.
I can now see that perhaps the test needs to be done with several weights that correspond to the amount of pressure that is imparted by a specific sail area in a specific wind. If we do that, we are now moving from home testing to that which must be done in a lab under better control situations.
I reckon my test and measurement to be akin to sticking my fingers on a “hot” electrical wire. “Yup ! There sure as hell is current there - but don’t make me touch it again to try to tell the voltage!” In my case, “Yup - the mast bends 1 inch at 20 lbs. over a 63 inch length. So now what?”
