Hi Breakwater and Row,
I’m still puzzled about the Draft I should consider !.
My intent is to satisfy 2 conditions :
1 - being fully compatible with Marblehead Rules where the draft can be as high as 12" and 16" for the Traditional and High Flier models and
2 - allowing separate racing of J Class and 12Metres designed models since their displacements are relatively different but using of the original Sail Plans/Rigs with the possibility to include different Ballast techniques like for instance the removable sliding fin/bulb. In this case art of the keel should be interchangeable. Some sketches will explain.
I do not have difficulties to match the Marblehead Rules.
Instead, the righting moment necessary for the increased SA or even a taller mast, can be achieved in various way, among these, the ballast can be increased in weight by modifying the hull draft and keeping the same water line, or increase the draft and consequently the volume to.
All that, with the desire to have the highest ballast ratio as possible !
Contrary to my model’s culture (deep fin/bulb combination see Class M) where the boat righting moment/stiffness is accepted up to 30°/35° heel, in the JClass/12Metres case as was written above, it is accepted that the models being more “gentle” and probably going up to 45°/50° of heel.
Of course watching the pictures presented above, it is understood that there is still the need to have an acceptable righting moment while being still “gentle”…
In the 1/16 JClass Rules it is agreed the use of a deeper keel to a maximum of 2 inches. If this it is done is because there is a good reason…
Form stability at model level is negligible.
From the interest expressed and exchanges made so far, I recognize that I was “pushing” too far the idea with the last presented drawing, although compatible with the Marblehead Rules, therefore I will come back to the previous approach by increasing the draft from 140mm average to 165/170mm, half of what it is allowed for the 1/16 JClass Rules.
I appreciate a lot this wide discussion with different opinions, this is exactly what I’m expecting from a serious Forum like this one.
The story is not finished yet …
All the best
