I will say, before a numpty sea-lawyer does, that some elements of this design come close to the footy rules.
This does NOT mean that they are not permitted, but might lead to debate
frinstance:
Batteries must be within the hull (as you say)
moveable ballast is not permitted
please build it (or its parents or children) - I dont think that the keel you have drawn would be necessary - the swinging keel would still provide the the side area.
Even with a fixed keel this is a sweet concept, and you have added ācharmā to the boat
Andrew
Is āballastā defined as that which provides righting moment to the hull, or as a counter-weight to keep the mast alone upright?
If the hull always remains flat to the water surface, then the fin and rudder will always remain vertical, and provide maximum side force to resist drifting downwind, rather than the force being greatly reduced as soon as the boat starts to heel.
Rod
Razor 08 CAN
Andrew
I was reading your contributions on the RCSailing forum, and have reached the tentative conclusion that a vertical aileron (aqualeron?) on the rear of the āstemā, controlled by a gyro, might keep the craft vertical in the water while it is moving forward, but how would you ever get it started from rest? It would surely lie upon its side at the first puff of wind.
Just a stray, random thought!
Rod
I am authorised by the Galactic Footying Council (Radical Front) to bid you alll Happy New Year, and in that order.
(This message is timed to be suitable for readers who use both the Gregorian and Julian calenders)
A vote will soon be taken on issuance of a similar greeting to adherents of the Lunar cycle who are approaching the Year of the Rat - similarly late.
How are the radical fleet progressing?
Rod - tell us, please of the scow and other mind-children
progress on Phinn-ihthy?
History man - how is your Phinn? Update us please (with references on previous use of triangular footys at the battle of of Zama 486BC*)
*Made up date, I am an adherent of Sellers and Yeatman
ZBF has marked time for a week or two - I am just preparing to glass the hull and do some serious re-inforcement of the joints in the carbon framework.
Savonifoot has got as far as a catamaran hull and the sails (trial versions) cut ready for mounting and balancing.
Is there any more thinking outside the footy box out there?
An attack of post-prandial torpor must have occurred, unfortunately reinforced by carpet-layers and house-painters.
I havenāt got down to the south end of town where the supply of carbon tubes is located, so have made no progress on the rig for Phinn-ichthy. I plan on a super-enormous sail area to support the featherweight hull, which is a mere two-and-a-bit kilograms. Does anyone remember offhand the pressure of wind/MPH/square foot? Iāve seen the number somewhere but am too lazy to search for it again (see above torpor). At a guess, would 600 sq in be too much for the sensiblities of Footydom?
Iāve looked back over some of the thread, and my jaw is hanging down in mixed admiration/appreciation/indignation with several other emotions - none of them mild.
I am an absolute novice and near-virgin at Footying (about 4 months) and am not aware of the past with its triumphs and scars.
I have no qualification other than an open mouth (and I hope) mind) and started this thread to allow the future to protrude into the present (a little).
You, Sir, have had a keek at the future and questioned everything thoughtfully - I look forward to digesting the threads you pointed us at, and the imagination behind it all.
Does anyone know just what is the static pressure of the wind in lb/ sq ft, per miles per hour, upon a panel at 90 degrees to the wind flow? I need to know this info to calculate the maximum sail area for Phinn-ichthy.
I am planning a 3 ft mast. I can determine the righting moment of the hull at half mast height, and need to know the sail area to cause a 30 degree heel at the prevailing wind speeds.
I am assuming that this is how the initial choice of a sail area is made by a yacht designer. Always before I have proceeded by eyeball and testing, but Phinn-ichthy is so extreme that I do not have any experience to go by.
Awaiting your collective advice with baited breath.
Rod
Hmm⦠Had to strip out a lot of non-essential information that Beauford so thoughtfully provided. The forum software doesnāt like my tab delimited table.
Three tries later all I can do is say I hope you can figure this out. Maybe I should try to make a jpg out of the table!
Angus ⦠Iāll resurrect the design, draw a rig, and even build the plug ⦠there is at least one local brain whoās done it full size (c-cats) who may ante up with practical knowlege and Iām guessing there is a persona-non-grata in Florida whoās also done it and who might be convinced ⦠that, however, is as far as I can take it (business, kids and an agressive off-shore campaign commencing in the next few weeks means my time is f*&#ed) soooooo ⦠unless a guy like Nigel (or ?) wants to fabricate her and unless youāve got a local someone who wants to fit her out and rig her, itās just paper Iām afraid ..
