the only problem I see… is if you have a bum servo…replacing is going to be a PITA… gotta have real small right angle screw drivers. Unless I’m missing something in the pics…it looks liek the servos are attched to a board…separate from the deck, but I dont see how the board is removed…
I use velcro on both sides of the lipo battery one to stick to the hull, and one to stick to the rx. works well on my other boats as well. the lead on the lipo is just long enough to hook into the rx…
What model footy is that…I like the keel trunk…
I’m heading to CA this weekend so I’m going to pick up a few v-12 hulls to play around with and I am now making my foils using Heli rotors… and they are all going to be interchangeable. so I have a 8oz bulb, I’ll make up a 7 oz and maybe a 6 oz. so I can swap keels and rigs. so if I know it going to be light air day. put in the big rig with a lighter keel bulb… and sail. Yes I know I can’t swap ballast during an event…
I have been known to carry a fishing pole and a 3-4 oz sinker and cast away…the key is to “miss the boat”
