Michaelb-
I have used System 3, WEST and RAKA’s blend. I find it much easier to carry a homemade carry box around the house, workshop, yard and boat with a can of resin and 2 cans of hardener - (fast/slow) than to worry about a set of scales. WEST can be seen to change color as hardener (gold) is mixed with the clear resin, so mixing complete is easy. I also use a “double-circle” mixing guide for very small amounts which would stick to the sides of a mixing cup.
They also formulate a clear finish resin, and their G-5 product which allows molds to be fabricated and used within 30 minutes. Nice for small parts, etc.
Warmed WEST will thin and penetrate - while “thick” can also be used. A little thinner - though not recommended - works great to coat wood without being too thick to add weight.
SYSTEM 3 is my next choice, as they have a good product that has also been well received by the general boat building public. Problem is that here in the upper mid-west of USA, you must mail order it, while WEST can be found in many local retail outlets and marinas/dealers.
RAKA is a product we tried last fall for a strip canoe built through our Parks & Rec. program. It was first time I tried it, and it worked OK - but again, the cost and issues of shipping a product from Florida up here. Not sure about down there, but here in the US, many resins and most hardeners can/are considered as hazardous chemicals, and transportation laws step in and create pricing issues. (Same for MEK hardeners for polyester resins). I found the RAKA to be easy to squeegee and wet out the glass, although I think the glass itself was a bit of a problem. I didn’t buy the stuff - so not sure - but it seemed it wasn’t cleaned and wanted to reject resin in areas. Perhaps it had hand oil in spots - don’t know - was just there for our use but supplied by Parks.
As noted, with WEST being available many places, it is easy to hop in car and drive to a retail outlet to pick up a can of resin or hardener. As you tended to infer, you do get used to a product and are reluctant to change to something new. Even cost considerations may not be enough to warrant a change.
To be fair, while I support the WEST products, it is fair to know that I grew up less than 30 minutes from their shop, worked with them on some projects and also sailed against them in dinghy and multihull events. Jan, Meade and JR Watson have provided me with much free but very useful technical advice, but I also count them as great sailing friends and as noted by some of the designs and builds from their shop, they do know what they are doing and have 35 years of experience behind them. If interested, you should visit their site and read their background and the projects they have been involved in.
An interesting observation however - doesn’t it seem odd, that one would (possibly) need to purchase 100 different kinds of resin/hardener formulations from your favorite company, and I can usually get by with a can of resin and two different speed hardeners for everything I ever wanted to build - big boats or little? Kind of like my multi-functional favorite tool - a screwdriver - that can be used for so many different things ! [:D] Sometimes simple “IS” better ! [;)]
Thanks for the views however - and I’ll let you know how the next RAKA project goes when I get to pick the cloth.
