Remember these quotes from a differnt topic … ???
A “Bruce number” is used by multihull designers to compare the power to weight ratio of multihulls.
The Bruce Number is a DESIGN comparison
There are some limitations on using the Bruce Number
<font color=“red”>Further, BN’s don’t reflect the intangible’s that show up on a race course</font id=“red”>
Model multihull’s, under both the mini 40 rule and the Formula 48 rule, are allowed to vary displacement as well as sail area further clouding the BN picture
My point in saying what I did was to caution people not to draw too many conclusions, at this point, regarding the application of Bruce numbers
Perhaps some correlation between BN and performance will be shown as time goes by
You can create BN’s for any size boat but their major value is in comparing similar boats
The fact that the X3’s BN with a spin is higher than an 18sq. has absolutely nothing to do with the X3 being able to beat such a large boat;
By compiling data such as Bruce numbers and working toward other methods of evaluating multihulls, perhaps thru a wider set of parameters, we are making a start on building an information base that will be added to over time. It may help us all see the relationships involved more clearly
BN numbers are just a start
This again reinforces the fact that collecting data such as BN numbers for rc multihulls with a perspective of using the data to help develop accurate ways of assesing an rc multihulls’ potential across the board including it’s proclivity to capsize/pitchpole (or lack thereof) is important. Going about promoting multihulls in the same old way just won’t cut it; there are solutions that can be developed.
BN numbers are a start…
I’m sorry it’s hard for you to understand the way Bruce numbers work; they have some limitations as pointed out several times in earlier posts. They appear to be accurate when comparing rc multihulls in light air and based on European race results maybe in heavier air as well.
In point of fact Bruce numbers are relevant for rc multihulls in light air when length (wave making resistance) and RM(righting moment) are not factors.
<hr noshade size=“1”>
All of the above are quotes and show a move away from a pure post to one that includes righting moment, water line lengths, sail area, wind speed and a whole host of other intangibles ? see the red post above. Notice how Doug kept adding in other “qualifiers”?
I suggest that my post is just as valid ? if not more so - than all of Doug?s quoted posts above: My post said ? ?The BAOW Performance Number (rating from 0 to 10) can provide a quick, effective and easy to understand guide number for determining which boat should be selected for your immediate, pending multihull purchase.?
I further went on to point out that?.
<font color=“red”>If the boat isn’t on the water - it’s rating is Zero ! You can’t buy one or sail one.</font id=“red”>
<font color=“orange”>If the boat is under construction - it’s rating will be around 5 depending on the level of construction! You can sit around and wait for it to be completed if you want to - your choice!</font id=“orange”>
<font color=“green”>If the boat is actually on the water and sailing, it rates a 10 ! If it is for sale you can buy it, take it home and go sailing!</font id=“green”>
Please explain why this set of ratings should any more confusing, be less useful, or do any more damage than those ratings posted by Doug. My ratings are based on actual boats that are either on the water or they aren?t. I?m not sure what part of my post is difficult for you to understand.
In the end ? performance is judged <font size=“3”><u>on the water</u></font id=“size3”> ? not by a bunch of databases and tables and numbers. If my boat (monohull OR multihull) finishes first ? that is the only number to which I care to relate or understand.
And Matthew ? we can compare my boat against your boat to no end by numbers and databases, until they actually do meet in the water. THen there is a factual outcome - not an outcome of theory! Remember, Doug is the one who indicated the Aussie multihulls couldn?t possibly be any good, - without seeing or sailing against them. Talk about confusing people!
Cheers - try sailing instead of analyizing - it is more healthy and more enjoyable.
