<blockquote id=“quote”><font size=“1” face=“Verdana, Arial, Helvetica” id=“quote”>quote:<hr height=“1” noshade id=“quote”>Originally posted by Dick Lemke
Phillip -
just an observation - depending on circumstances, adding weight to your Tornado may increase chances of capsize, as you have just added to displacement, and if hulls aren’t buoyant enough to handle the extra weight, (and able to accelerate in the gusts) you may find the added weight more of a problem than a solution. All would depend on the starting design displacement of the boat, and how far off the designed waterlines the boat is floating.
OK, That makes a lot of sense. My plan is to use about 2lb of movable ballast (the weight of the weightshift motor and battery) on the Tornado, replacing the 2lb of lead on the keels. The idea is to have more intelligent weight distribution.
I am not directing the following at you - only making it as a general statement - “in making changes to a model, of a percent of weight, change of buoyancy location, increase/decrease of waterline or beam, and finding a negative reaction, it seems too easy to blame the boat - and not the modified design parameters.” I am sure you wouldn’t expect a plane to fly (or stunt) if you added more weight, so I would caution others to keep the “design specifications” in mind when someone modifies a design and the results aren’t as positive as expected.
True…
We seem ( in the multihull area, especially ) to quickly blame the design for capsize - and seldom take into account the experience of the skipper, the speed or strength of the winch/servo, the size of the sail area or the height of the rig… all we see is another multihull that capsized.
Yesterday, as I rescued my capsized Tornado from the reeds yet again, this question entered my mind… I was trying to sail the boat in winds that were just too much for it. I’ve come to the conclusion that I definitely need a smaller rig for stronger winds.
Philip Rawson
