Photos to follow but a quick update…
Having successfully trialed epoxy resin over acrylic paint I set to waxing the plug. Lost count in the end but it had at least 8 ‘coats’ of Meguiars Number 8 release wax. Final coat was allowed to dry overnight (probably not necessary) and the laminating commenced.
1st layer was 165g/m2 glass twill with an approx 30mm overlap down the centre line. 2nd lamination was 290g/m2 glass twill but this time carefully trimed to the centre line. The main reason for this is that I didn’t want to build up undue lamination thickness either side of the line. Also, the weight of the cloth wouldn’t lie evenly over the fine bow sections. 3rd lamination was 165g/m2 glass twill once again but this time with an approx 40mm overlap either side of C/L. The aft face of the keel was left open to assist in de-molding (discussed earlier in thread and also in Claudio’s ‘Enterprise’ build log).
It was at this stage that I made a bit of a mistake which I’ll cover later. Anyway, once I was happy with the glass work and sure that the cloth was fully wetted out I consolidated the laminating with a bristle roller which had been recommended by my supplier. Following this I used a squeegee to remove excess surface resin and then started laying on strips of peel ply. This is when things started to go wrong.
As the peel ply was layed on it soaked up the last remaining excess resin BUT there were one or two dryish patches, so I mixed a little more epoxy and started to stipple it on with a brush. This in its self wouldn’t have been a problem. Unfortunately I started rushing - we were going out & I was running late. Happy that the peel ply looked even I shut up the workshop and left it all until the following morning.
So, 15 hours later… On removing the peel ply I was faced with the mess from hell. Pooling and runs were abundant and lets face it, epoxy puts up a pretty fierce defence to sand paper. Why on earth didn’t I squeegee again after the application of the peel ply? I’m almost embarrassed to post the pictures but I’ll add them to this post sometime over the next few days. What to do?
Ignoring my ‘faux-pas’ for the time being I decided to see if the ‘hull’ would release from the plug. The first gentle upwards tug midships resulted in a fairly easy separation of the topsides and initial inch or so of the turn of the bilge. I then took a strip of softwood (planking offcut) approx 1.5mm x 3mm x 250mm and eased it between the hull and plug at an angle of 45 degrees. Repeated 2-3 times down each side resulted in the separation of the rest of the bilge but still no sign of the keel area separating. The same size strip was then inserted through the open aft face of the keel and result!! Separation complete and the molding lifted easily away from the plug. Others on this forum had suggested that separation could be problematic and although I was inclined to agree with them, on balance I felt it was worth a shot and fortunately it paid off.
The hull was then placed back on the plug and I began sanding with 60 grit paper to start removing the excess epoxy. After an hour or so progress was virtually un-noticable. A bit of a rethink was required…
The inside of the moulding is virtually flawless (1 or 2 very small areas requiring remedial attention) which got me thinking. The outside is so bad that I reckon the easiest option is probably to add additional glass and battens etc to strengthen it further, split it down the centre line and use it as a female mold. I can’t foresee too many problems with this solution but if others have any other observations and/or suggestions they would be gratefully appreciated.
Thats it for the time being - I’ll add some pics over the next few days.
Row
