Hi Scott,
I appreciate your comment on my treads and effort in exhibiting this table, but in my opinion there are some mistakes and the most important one is the use of the rotational parameter that cannot be considered other then speed and power consumption.
Here my first comments to your table :
As you can see, is not sufficient to extract the manufacturer specifications. What it is important is just the torque value at a given voltage supply.
In my opinion, the “work” done could be used to verify eventually the energy consumption of each single servo under load.
conditions.
Just an example, you suggested that 392kg.mm is covered by most of the servos.
1st - the 392kg shall be multiplied by a safe factor that contains frictions, tolerances and a security margins. In my case I choose a factor of 2, therefore one should read 392 x 2 = 784kg.mm
2nd - the Eurgle you listed with 4505.0439 drum-work was not capable to pull back the main of 5073cm² when a gust of 16/18 kt arrived. This point is visible and commented in the published film.
Because the effective use was with 2.94 revolutions, then your formula : “drum_work[kg-mm] = torque[kg-mm] x (rotation[degrees] x pi/180)” will suggest : (119.5 x 1061° x 3.14) / 180 = 2211.7733 and not as you calculated 4505.0439, by taking all the Mfg. parameters. If further you modify the voltage supply, your figures may drop substantially !
3rd - based on above all your calculated values should be revised as function of the effective conditions of use.
With the need to get a kg force of 784, the last servo in the tables cannot be use ‘as is’ unless with the arm configuration.
The RMG are for the time being excluded because expensive.
Most of servo listed are valid with the “arm configuration” so far they can be maneuvered with 120° minimum to avoid too long arm and consequent loss of power.
There is a drawback that I do not like, and this is the rotational speed that in my opinion is often too high. Many boats has been already damaged because of that.
Of course one could educate himself to move the joystick in accordance with.
Finally the torque power of several servos listed above could be exploited with the use of a drum, but to do that there is only one way : external potentiometer.
There is also another concern is the power consumption. If I desire to contains the overall weight, I shall consider the battery pack weight and cost.
I remember another problem with arm servo, some times, under continuous pull effort they may burn out, this happen to me with the HS-815BB on the AC33 project, probably was my mistake to let my boat in the hands of somebody else !!!
So, as recalled above, not easy to come up with a solution unless you are prepared to spend a lot of money and accept the excessive weights of some dated servos.
All that of course is valid when reported to my design where the overall weight limit is the most important parameter.
The solution I have retained for the time being has the merit to be less expensive and not very heavy.
Hope one day to see a drum servo more powerful and a bit more faster then the HS-785.
